how to keep a key in place while installing a jaw coupling on a verticle shaft engine
tuco1963
57
east central indiana
helpppppppppppppppp
its driveing me nutsss
i put it on thje shaft and when i put the coupling on it falls off
helppppppppppppppppp
thanks
charlie
ps
its the right size key
Grease?
Reactions: Fifelaker
Can you glue it in place?
Some duct tape to wedge it in the slot if you are in a hurry.
Big rare earth magnet on shaft.
Thats about it with out seeing it.
Good luck Thomas
thanks gang
if it warms up today im going to try working on it
when i get it done i will give an update on what worked
thanks
charlie
Try a sharp center punch. Place the key in place and stake it in place by punching the top edge of the key way where it meets the key. It will slightly pinch the key way enough to hold the key in place.
Reactions: iceguy4
Jet lube brand mp silcone grease. Words most sticky tacky grease.
Install with a thin piece of paper on one side, tap in place. Tear off excess. Grease works too but I find the paper "binds" the key in place a little better.
