    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. AppalachianStan Feeling the Heat
    Clover SC
    How do you put in a Catalyst Thermometer in a wood stove that dose not have?
    #1
    Helpful Sponsor Ads!
  2. mellow Minister of Fire
    Salisbury, MD
    Stan, sometimes you make no sense.
    Anyway, if your Appalachian is like mine you have a port near the damper control rod to put the cat probe into, it might have a screw in it that needs to be taken out.
    Not sure how different our stoves are but you should check out my review of the Appalachian 52 Bay Insert - My Review
  3. AppalachianStan Feeling the Heat
    Clover SC
    My Stove is so old it did not come with the hole for Cat Thermometer.
  4. mellow Minister of Fire
    Salisbury, MD
    Then drill a hole in about the same location as mine, your cat housing is very close to mine. That is if you would go ahead and buy the cats. Give Matt a call at Servicesales.com, he will be able to hook you up.
