    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Bezalel New Member
    I'm thinking of picking up something like this ...
    10 Ton Hydrolic Splitter
    If this works well, I can go ahead and order the Ryobi 4 Ton Electric Splitter. The Ryobi will be for processing most of my wood, and the manual 10 Ton unit will be for those larger stubborn logs. I am thinly built and can't do much with a 8lbs maul!
    #1
    Helpful Sponsor Ads!
  2. Eric Johnson Minister of Fire
    Central NYS
    I would buy the Ryobi and see if it splits your toughest wood. I suspect that operating those hand-operated hydraulic splitters get old pretty quick, and you may find that the Ryobi does most, if not all, of your wood.
  3. Roospike New Member
    Eastern Nebraska
    Manual hydraulic splitters are painfully slooooooooooooow..................
  4. ourhouse Minister of Fire
    Franklin Ma
    They don't work very well. the guy next door has one and he hates it.
  5. elkimmeg Banned
    look at it this way when is the last time you used a hand saw to cut a full piece of 3/4" plywood
    cutting the plywood maybe quicker than that manual hydraulic splitter Its a 10 ton jack
  6. Chuck Pearson Member
    Adrian, MI
    I have an 8 ton manual splitter. It is fast enough for me but the first jack failed in a few weeks and the replacement failed six months later. After the second one failed I ordered a Japanese jack from a separate source. It was rated at only 5 tons but had a bigger ram than the "8 ton" original (Chinese?) jack. The answer to your question is that a manual splitter works well if you have small quantities or a lot of time but durability could be an issue.
Thread Status:
