Youre damn right it does. Makes the air seem much more dense and warm as well. Mine is running as we speak.Doing The Dixie Eyed Hustle said:I need one. The stove top steamer might look good, but it isn't cutting it.
Makes a difference with sinus issues.
Short and sweet and correct!rwhite said:If equal volumes of air and water are heated to the same temp, the water will retain the heat much longer. Water vapor from the humidifier increases the airs ability to hold heat.
Fiziksgeek said:rwhite said:If equal volumes of air and water are heated to the same temp, the water will retain the heat much longer. Water vapor from the humidifier increases the airs ability to hold heat.
While true, I do not believe that is the driving force. Its a complicated process with many contributors including increase in heat capacity, decrease in air density, increase in conductivity, and what might be the biggest factor, an increase in relative humidity when you turn on that humidifier. As you warm the room, the relative humidity drops, you haven't removed moisture from the room, you simply increased the amount of moisture needed to remain at a constant relative humidity. Low humidity mean more evaporative cooling, more moisture from your body entering the atmosphere, cooling you off in the process....
rwhite said:Fiziksgeek said:rwhite said:If equal volumes of air and water are heated to the same temp, the water will retain the heat much longer. Water vapor from the humidifier increases the airs ability to hold heat.
True but the OP asked if higher humidity would keep a house warmer. Given two identical rooms heated to the same air temp, the one with higher humidity will retain heat longer than the other. Conversely the drier room will heat faster and cool quicker. That how it can effect inanimate objects. As far as how the higher humidity makes a person feel then you are absolutely correct.
pen said:Most say that moister air will feel more comfortable and therefore feel warmer.
For me, I humidify to keep the wife from walking around w/ wads of tissue stuck in her nose.
pen
There are different technologies to put water into the air. When water is vapourized, it said to have gone through a state (or phase) change and this change absorbs heat causing a cooling action. This evaporative cooling action is used to advantage in cool misters and swamp coolers. Room humidifiers that don't use heat will actually cool the room.Hass said:I know a dehumidifier produces heat.... mine is a 45pint and uses 600w... so a good amount of that comes back as heat...
