    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. HDRock Minister of Fire
    Grand Blanc, Mi
    #1
    Helpful Sponsor Ads!
  2. HDRock Minister of Fire
    Grand Blanc, Mi
    This is the info I found out about this problem
    The round metal piece with the 2 notches is too long. This is common with this series of saws(61,266,268,272) when you mix and match from the original. I've dealt with this many times. You can probably grind a little off the end to fix your problem. Sometimes what happens is the plastic air defector can make the difference. On early models the deflector did not fit under the starter mounting screw area and on later models like the 268,272 the deflector fit under the starter completely and in effect moved the starter away from the flywheel by the width of the deflector.
    Usually when you have a setup like you have,the starter won't retract because it's so pressed into the flywheel and can't move freely. Someone could have changed the reel from the original,who knows. Should be easy enough to fix.
