    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Mtn Fire New Member
    New Mexico
    Hello out there,
    On a typical hydronic gasifier, how much powder or creosote is brushed out during an annual cleaning of the exhaust and heat exchanger tubes?
    thanks in advance,
    Alex
    #1
    Helpful Sponsor Ads!
  2. AroostookDave New Member
    Aroostook River Maine
    I clean the tubes monthly - after I clean the ashes from the lower firebox, I reach into the top access, bang each turbulator up and down a couple of inches to knock the ashes off and then scrape the base again. Usually not much ashes but worth doing. 2 or 3 times a year I get the brush out, but never run into creosote, so no big job. I clean the horizontal section of the flue a couple of times per year, but never find more than a thin coating of fine ash at the bottom.
  3. Mtn Fire New Member
    New Mexico
    thank you,
    Alex
  4. bmblank Member
    Michigan
    My dad and brother are in the once a year club. Through the entire chimney there's maybe a gallon and a half of creosote. That's probably 30 feet out so of chimney.
  5. Mtn Fire New Member
    New Mexico
    Hello,
    Is the creosote in the boiler or just in the chimney? Thanks for your reply.
  6. BoilerMan Minister of Fire
    Northern Maine
    A properly tuned and seasoned wood burning gasser produces no creosote, just a grey-black flyash. Creosote is an indication of something not correct or a lot of idleing.
    TS
  7. Rory Member
    Central Me
    I agree. I'm on my 5th season with my Tarm Solo 30, and I have yet to see any creosote in my chimney. I clean my heat exchanger tubes a handful of times each year, and all I get is fly ash. I've burned a fair share of softwood in my mix, too, but still no creosote.
  8. bmblank Member
    Michigan
    Ok, i guess i call fly ash creosote. I get a little creosote in the firebox near the door, i open the door too often, its still new to me. Anyway, i clean out the secondary every burn or couple of burns and get about half a gallon of fly ash.
  9. James Reimer New Member
    Winker, Manitoba
    I run a brush through my horizontal tubes once a week as part of the regular cleaning cycle. Takes only a few minutes and I get maybe a cup of dry ash a week from the tubes themselves.
  10. Mtn Fire New Member
    New Mexico
    thank you,
    Alex
  11. Mtn Fire New Member
    New Mexico
    Thank you,
    Alex
  12. Mtn Fire New Member
    New Mexico
    Thanks,
    Alex
  13. McKraut New Member
    South Central PA
    Alex,
    I clean my exchangers (eight of them) once a year and I get less then a soda can of residue out of them. I've never had creosote in my chimney. The only blockage I ever had was a starling that decided to fall down the chimney and wedge himself in there. After I put a "roof" on my chimney, I've never had anything to clean out. I hope my two cents help you.
    Bob
  14. Mtn Fire New Member
    New Mexico
    Thank You Bob,
    Alex
