dr.drew said:
BeGreen said:
I'd go for the Republic. It's not so much about heating capacity, you control that by the amount of wood put in the stove and air supplied to the fire. But it's hard to coax an overnight fire out of a small stove and the only solution there is more capacity.
do you know anything about the endeavor same heating as the pepublic
The Endeavor features a bypass damper, which the Republic does not have. The is a metal plate at the back of the baffle that slides open to allow the flue gases to go directly up the flue. It is useful for getting a good draft going when starting from a cold stove. It's also useful during reloading. And, finally, when it's time to sweep the flue, you don't have to remove anything from the baffle - you just open the bypass, sweep, and all the soot falls into the firebox.
There are some great videos at
www.lopistoves.com/videos if you want to watch them. There is a factory tour that shows an Endeavor being made, and there is a technical video with a cutaway Endeavor showing you how it all works.
Lopi uses stainless steel burn tubes, kiln fired clay fire brick, and heavy angle iron to construct their baffles. The stove unibody is 3/16" plate steel, and the stove tops on the Endeavor and Liberty are 5/16" plate steel. Quality product. Watch the videos and check one out. I don't think you can go wrong with Lopi.
Edit: see my Endeavor review here
https://www.hearth.com/econtent/index.php/forums/viewthread/37171/
