I just put in an Englander 30-NC in my walk-out basement, and all seems fine, except the fire seems a bit starved for air with the door closed and the air inlet fully open. The folks at Englander reviewed the overall situation, and feel the most likely cause is insufficient draft. Mike, a member here on hearth.com (stoveguy2esw), also gave me some advice, but before I made any major changes, I wanted to ask for some more opinions.
The house was built in 1951 and isn't that tight overall. There are three flues in an external chimney, one for the basement fireplace, one for the upstairs fireplace, and one for an old furnace, which is no longer used. The sweep opted to drop a 6 inch SS liner down the unused flue, because it was in great shape, and because it avoided making any changes to the basement fireplace. The stove now sits about 3 feet to the side of the basement fireplace.
There are two 90 degree elbows, and a short horizontal run of about 2.5 feet. It's about 25 feet to the top of the chimney.
The sweep tested the draft with a puff of ash, in the middle of summer, and it went right up. He said there would be no problem with draft in the winter, though it's safe to say that's a guess on his part. If I take the stove apart, the draft I feel with my hand seems fairly robust, though I know that's not very accurate.
The fire starts great, and roars away if I just keep the door open a hair. If I seal the door, the fire visibly fades, and flames come and go at the edges. If after a while I crack open the door, all the logs burst into flames again. I'm no expert, but to me this seems the fire is starved for air.
Opening a nearby window seems to make no difference.
I'd really like a way to prove where the problem is, before I do anything about it. I know draft can be checked with a manometer, and I have access to one, but it seems to me the reading is only valid when the liner/flue are hot, which would require the stove to be going. Measuring it when cool will lower the draft reading, won't it?
And if opening a ground-level window makes no difference, does that also mean an outside air kit will make no difference?
