Okay so I am about to buy a T5 Insert, but the following came up when I visited the dealer and talked about a the block off plate, insulating the liner, and a question about the install itself. Any advice on all or some of the items below would be great.
1. The installer indicated that he didn't want to put in a block off plate as he will seal the chimney cap air tight. I then suggest I could build the block off plate – the installer indicated that he would not install something that I built. I know that sealing the chimney cap air tight is not the same as a block off plate, but would an air tight chimney cap be an “okay†substitute�
2. The installer indicated that it was not necessary for the chimney liner to be insulated and would not do this – he even went on to suggest it was not to code here in Canada, would any of the Canadian readers know the answer to this?
3. The installer suggests that I bring in air from the existing “ash dump†to feed the insert which is okay by me (I know some on this forum are dead set against this, but I do not want to turn this into an outside/inside air debate, so if possible please refrain from suggesting I use inside air) – the thing is, I read in the Alderlea manual the following:
The installer indicated that there is no need to seal the fireplace – anyone out there with a Pacific/Alderlea insert can tell me what they did in terms of
sealing the unit when using outside air?
Thank you everyone for all of your help. I know some comments will come back suggesting to go to another dealer or go with a different insert, but for a variety of reasons this is it up here in Calgary for me, buy the T5 insert from this guy and have him install it the way he wants to or get nothing.
4. What would you do, would you still get the insert even with the above stipulations?
Dan
PS. Sorry for such a long post.
Outside air (O/A) supply: Remove cover from ash clean out in existing fireplace. Place a rodent screen in place of the cover. Install the Insert as described in the installation section, making sure not to cover the opening of the air inlet. When installation is complete, seal surround to fireplace and anywhere else air may enter. This will ensure combustion air is drawn from outside the house and into the 9†x 2†intake at the lower rear of the appliance.
Dan
