We have a large see through stone fireplace (31"h x 40"d x 44"w). We are debating whether to set a freestanding stove in the fireplace, or to use a insert (most likely a PE Summit either way).
We kind of like the freestanding stove idea since an insert would require some sort of hearth extension (the hearth is 16" and 12" above the floor). Also, a freestanding stove would provide some heat to both the front and back.
However, I also realize that some of the heat would be lost to the stone fireplace surrounding the stove on the sides and above.
Also, we would have a really tight fit getting the freestanding stove into the fireplace since the hearth is two inches higher than the firebox (29" clearance). I'm thinking of getting the stove with the legs and cutting a couple of inches off the legs to lower it a bit. Or alternately, leaving the legs off and sitting it on bricks on each corner.
Questions:
1) Are we going to loose a lot of heat to the fireplace since it will be surrounded by stone?
2) Does anyone see a problem with lowering the legs a few inches?
3) I already have sheet metal blocking the existing chimney below the old damper. I'll cut a hole in the sheet metal and run 6" ss flex tube up the chimney. How does one connect a stove to the flex tube since I won't be able to lift it up and set on on the stove? (Or is there enough "extra" in the collar to do this?
Alternately, if we go with an insert, it will be about 12" horizontal distance from the stove flue connector to the flex liner coming down the chimney. How do I handle that horizontal distance, with a couple of 90s or 45s?
Thanks,
Ken
Questions:
Thanks,
Ken
