    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. EJL923 Feeling the Heat
    Western Mass
    My first big project this year is replacing the two doors on my garage, 9x7. The current doors are old, no saving them. I do all my own reno's on my house. The only thing i prob wont do is my roof, little steep.
    I am looking for tips on buying ans installing garage doors. Brands to buy, styles to buy, what not to buy.
    Also looking for tips on installing. Doesnt seem overly difficult, just time consuming it seems.
    Thanks
    Eric
    #1
    Helpful Sponsor Ads!
  2. davmor Member
    Northern Michigan
    Buy the best doors you can afford, you will not regret it. The last door I installed was on my new shop, garage. Make sure you buy good angle iron to hang the tracks from the ceiling rafters. Some manufacturers have doors in the color you may want. It is not that hard of a job. Take your time, read the instructions, save yourself a lot of money :).
  3. nate379 Minister of Fire
    Palmer, Alaska
    9x7 will be cake to do by yourself. I did one last year for the shed I built. Never put a door up in my life and I had it all done in an afternoon.
    I used a Wayne Dalton 9000 series, around 2" thick, I forget the R rating. Was about $400.
  4. velvetfoot Minister of Fire
    Sand Lake, NY
    I haven't done one, but I recall warnings about being careful with the springs.
  5. heat seeker Minister of Fire
    Northern CT
    Insulated doors make a big difference in the winter. And I second not buying cheapo doors - buy the best you can afford, it will pay in the long run.
  6. velvetfoot Minister of Fire
    Sand Lake, NY
    I did once install an opener on on door that wasn't reinforced for the purpose and it bent it a little.
  7. greg13 Feeling the Heat
    CNY
    If you buy the style that uses the type of spring that mounts to the wall above the door, USE EXTREME CAUTION when you tension it. One wrong move and you run the risk of a broken arm or a bar to the face. I would recommend installing the door yourself than have a pro come in to do the final "Adjustments".
  8. nate379 Minister of Fire
    Palmer, Alaska
    No worse than anything else that is under tension, car struts, tranmission springs, etc. Just be careful, save the beer till after and it'll workout just fine. I would not sugest to someone that has trouble using a screwdriver to mess with it of course, but the average home handyman probably knows just as much on door installs then many of the "pros".
  9. EJL923 Feeling the Heat
    Western Mass
    The consensus seems to be to buy a good door. Any other good names out there?
  10. ironpony Minister of Fire
    mid-ohio
    as stated above be careful with winding the springs
    slow and steady, keep others away
  11. heat seeker Minister of Fire
    Northern CT
    The long springs that go along the sides of the rails are the safest, IMO. When the door is up, there is little to no tension on the springs. They are easy to install and adjust. It is important to install the cable that goes through the springs to contain them should they break. It's code around here. Many years ago, I had a spring break, and it left a significant impression on the door frame. The center cable would have prevented that.
    I can't recommend a brand, I had mine installed by a dealer.
  12. nate379 Minister of Fire
    Palmer, Alaska
    Do they still make that style of door anymore? All the the ones I have seen in the last ~10 years have the spring on the rod over the top of the door frame.
  13. heat seeker Minister of Fire
    Northern CT
    Yup, got mine about two years ago.
  14. Gary_602z Minister of Fire
    Lake Odessa,MI
    The torsion springs are really no different. When the door is up there is little tension on them and there is a rod running down the center that keeps it contained
    if it does break. I had one break on our 16x8 door one night about 2 in the morning. Sounded like somebody ran their car into the house!
    Gary
  15. heat seeker Minister of Fire
    Northern CT
    I've had two break over the years. They seem to go when no one is around (good!), but they do make a racket!
    Back when Chrysler products had torsion bars, they would snap occasionally. Every one I heard about snapped when the car was parked for a while, never when it was in motion. I'd think springs and bars would break when under motion, but apparently not.
  16. greg13 Feeling the Heat
    CNY
    Both style springs are still used. I personally feel the long side style are safer & easier to install, but they do take up more room than the overhead style. All I am saying is to use caution if you install that style spring.
  17. thinkxingu Minister of Fire
    S.NH
    I usually do all my own work, too, until I found out that it was only a couple hundred bucks to have my two doors installed--if I recall correctly, it was $1200 installed for lifetime warranty doors (vinyl clad aluminum with foam insulation). That covered everything, including lifetime warranty for parts/labor.
    S
