    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Boog Powell Minister of Fire
    NE Ohio
    Hey folks, is there a proper orientation from a mechanical standpoint as to which side of a Rim sprocket is facing outwards. I always assumed that the side bearing the manufacturer (stihl in my case) and size (3/8-7, .325-7, etc) should face outwards. However, two of the saws I acquired recently had the Rim reversed with the "holes" showing. Does it make a mechanical difference, or as in bar side rotation, is it actually good to occasionally rotate your Rim to give it even wear on each bearing side? Or maybe like cords/belts in a tire, it is best to maintain it in one torsional direction for its service life. Anyone have an opinion out there?
    #1
    Helpful Sponsor Ads!
  2. Nixon Minister of Fire
    West Sunbury ,Pa.
    It'll work either way .
  3. Boog Powell Minister of Fire
    NE Ohio
    The other thought that I forgot to mention is that it would probably stay cleaner and not clog with gunk if the holes were installed towards the clutch.
  4. MasterMech Minister of Fire
    Hudson Valley NY
    Most of the wear on a rim occurs from the outside in, so IMO flipping it won't significantly extend it's life. I usually install it with the identifying marks facing out but that's just my personal little bit of OCD.
    Thistle and Scotty Overkill like this.
  5. amateur cutter Minister of Fire
    West Michigan
    Yep, that way I know what's under the cover at a glance. Tried em both ways, & they don't wear any different. A C
  6. Pallet Pete Minister of Fire
    Ovid MI
    Funny I never even thought about this.
    Pete
  7. Boog Powell Minister of Fire
    NE Ohio
    I never had either until Lukem posted about how his "grenaded" into pieces the other day. Got me thinking about preventive maintenance ;) .
    Pallet Pete likes this.
