    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. danthman New Member
    NEPA
    I installed my direct vent LP fireplace insert over the weekend and installed the vent pipe through the existing chimney flue. After installing both pipes and getting the stove situated I noticed there was quite a cap in the flue around the liners. Anyone use insulation to seal this space? Will my vent pipe get too hot for fiberglas insulation? I am just worried about it maybe melting or causing a fire in the flue. I was going to stuff some fiberglass house insulation in there (with the paper removed) anyone think this is a good idea?
    #1
    Helpful Sponsor Ads!
  2. Inside Guy New Member
    Don't put insulation in contact with the chimney, the isulation should be at least three inches away. Your best bet is to caulk the gap between your ceiling or wall firestop.
  3. danthman New Member
    NEPA
    I can't caulk it because it's in an existing firebox. The vent liners go up through the damper of the existing fireplace. I think what I will do is make sure there is no insulation touching the exhause vent pipe.
  4. jtp10181 Minister of Fire
    Madison, WI
    The manuals for the gas inserts we sell specifically say to jam fiberglass insultion up there to seal it. It is perfectly safe for the ones we install. Check the manual.
  5. R&D Guy New Member
    Agreed. Check the manual, typically fiberglass insulation is stuffed into the gap. What kind of unit is it? We might be able to look it up together.
  6. danthman New Member
    NEPA
    Thanks guys. I looked over the install book that I got but it doesn't say anything about filling the gap with anything. The unit is an Empire Innsbrook. I appreciate all the help.
  7. 69Stingray New Member
    Southern, NH
    I have a 3" pipe going up an 8" insulated chimney (for a pellet insert). Can I put fiberglass insulation around the 3"?
    Never mind. I read the manual and it says fiberglass is OK. Plus, this is the gas section, not pellets!
  8. trafick Member
    Lynchburg, VA
    danthman,
    When they installed my DV gas stove in a masonry chimney (fireplace), they put a sheet metal plate under the smoke shelf (I had no damper). The two 3" lines for the stove ran through a hole cut into this plate.
    The installer said that this plate was not really needed but he liked to do it to keep cold chimney air from coming into the house when the stove is not in use and the exhaust pipe is cold. He also said that stuffing around the gaps with fiberglass insulation was OK. jmho
  9. Fire Bug New Member
    Clarks Summit,Pa.
    Are you guys talking about puting firberglass insulation all the way up the chimney between the liner and the flue or just between the liners and the damper opening?
    My damper was left on but left in the opened position with fiberglass insulation stuffed between the the open damper and the liners.
    I was told by the installer that this was ok and I believe,(as mentioned above), that Heat & Glow has this listed in the owners manual for my FB Grand owners manual.
    Sometimes I have heard of installers using what is called a Block OFF Plate in lieu of the open damper and fiberglass insulation.
    John
  10. stovetechri New Member
    southern new england
    fiberglass insulation will not burn, after all its glass. i put it around wood stove pipe and dampers. melting point is over 1800 degrees.
  11. jtp10181 Minister of Fire
    Madison, WI
    You cannot put fiberglass insulation around wood stove pipe or liners, the liners are rated to 2100 deg (with proper insulation) and as you stated the fiberglass is less than that. This is why they sell special insulation for wood liners.
    Fire Bug, yes just in the damper area. The FB-Grand manually specifically says to do this.
  12. stoveguy13 Minister of Fire
    CT
    the best way to really go is the same as wood insert it is to use a sheet metal block of plate insulation is allowed in alot of cases it can get some moister in it from the summer months and can start to fall out over time i have seen it laying on top of the firebox. not my first choice.
Thread Status:
