I have run into a bit of differing opinions on two subjects regarding my rigid single wall liner:
Somewhere in the NFPA 211 it is stated insulation is NOT permitted over pipe connectors...is the mineral wool blanket I am going to wrap the rigid single wall with considered insulation? I have a 30 degree elbow in the smoke chamber and one above the damper block off area...I was going to wrap all the way down to the top of the lower elbow. Is this not advised?
Secondly, BEFORE I screw all my vertical pipe and elbows together is there any reason that I should think of sealing/cementing each joint? I have been told be one stove shop it is necessary, and another claims the complete opposite.
Thank you
Thank you
