Insulation behind faceplate to prevent heat loss?
BURNSOFTEN
16
Fairfield Cnty - CT
Is this a bad idea? did my installer forget to do this?
The faceplate around my insert doesn't sit flush with the stone surround. The stone surround isn't a flat surface so I wouldn't expect it to sit flush but I'm worried this is causing major heat loss. I want to insulate that area since the sides have and inch + opening....this sounds like a fire hazard...any advice from the experts...
It might not be a safety issue. How is the stove vented? Was the stove installed with a full liner?
Hi BeGreen,
Thanks for chirping in on this
Yes, insert is vented through chimney using 6" insulated pipe
You should be fine then.
