Insulation for insert install?
WharfRat
9
Raleigh
Having an insert/insulated liner installed tomorrow and was wondering about "insulating" the chimney. They are not installing a block plate, so I was wondering if I should insulate the gap around the liner as it goes through the "throat". If so, what material should be used? There is also a gap between the front of the old chimney and a new facade that the previous owners had installed that I would like to insulate (fill in). The insert will only be used as supplemental heat, I'm guessing a few times a week and weekends. Thanks
If this is an exterior chimney a block-off plate can make a nice difference. In the least have them stuff the damper area with roxul or kaowool. Be sure they clean the chimney well including the smokeshelf area before installing the liner.
It is an interior chimney, but you answered my question exactly. I figured it would make sense to stuff some insulation in the damper area, Thanks
