OK, I stand corrected.
(We never had any pigs around when I was growing up....)
Hydronics...you have EKO 60, when it says 'in out-building" do you mean into a building other than the house and heating the houseNote that these responses are for indoor gasification boilers which use much less wood than outdoor boilers.
Yes, it's in a 12x20 building 150' from the house.Hydronics...you have EKO 60, when it says 'in out-building" do you mean into a building other than the house and heating the house
with it ????
regards
I was. Had a central boiler 6048. Hadn't really done me wrong, just got tired of feeding it 10-14 cords a year. Switched to an eko60 with 2000 gallons of storage this year. Pretty happy so far. Should be a lot happier next year when the moisture level of my wood is lower. Still a fine unit, just not operating as well as it is capable of.The poor reviews I was talking about on YouTube were from outdoor boiler owners. Sorry I didn't specify.
Anyone with an outdoor boiler unhappy?
Your wood consumption should drop quite a bit. How long can you heat on that 2000 gals?I was. Had a central boiler 6048. Hadn't really done me wrong, just got tired of feeding it 10-14 cords a year. Switched to an eko60 with 2000 gallons of storage this year. Pretty happy so far. Should be a lot happier next year when the moisture level of my wood is lower. Still a fine unit, just not operating as well as it is capable of.
Not 100% sure yet. I got a late start this winter, and only have about 30 day operational.Your wood consumption should drop quite a bit. How long can you heat on that 2000 gals?
I have an old 1980 fireking boiler that I had in a shed. I was not happy the first year after feeding it 15 cords, but then realized on the second year that I didn't do enough homework on the install. 175' from the house with 1" lines with my circ pump was not good.
Over time I learned more and changed things.
I ended up moving but I took my boiler with me. It heats my shop now and I'm working on adding storage to it etc. I'm building the new system around my next unit (gassifier) new 8" flue 2" manifolds 1000 gal storage.
In the end I've spent maybe $2000 on the system total for 5 years and it is still working. I don't plan to change to the gassifier for another few years at least because I want to get more value out of it. Its a trade off with the extra wood consumption.
I can see if you don't do your homework on these units it can be torture.
