Is Location of Electric Water Flexible?
velvetfoot Posted By velvetfoot, May 3, 2014 at 7:18 AM
Thread Status:
  1. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,430
    711
    Loc:
    Sand Lake, NY
    I'm toying with the idea of moving my electric water heater from one place in the basement to another. It seems to me that as long as I tie into main lines, so to speak, the location shouldn't really better. I'm thinking about creating space for other stuff, and relocating a potential noise source (an as yet undelivered add-on dhw heat pump._.) There may also be some benefit for faster hot water realization upstairs. What do you think?
  2. yooperdave
    yooperdave
    Minister of Fire 2.
    NULL
    Oct 26, 2010
    1,127
    210
    Loc:
    Michigan's U.P.
    Years ago at a different house, I was in the same scenario as you. I had a chance at a full size brunswick pool table (3-piece slate bed) and accessories for $250. Understandably, the water heater was moved! Only concern I had was that it was being placed farther from the bathroom and closer to the kitchen. I don't remember having to let the water run a long time for hot water to show up in the mornings...and I'm sure I would have heard about it if that was the case!!
    Go for it
  3. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,430
    711
    Loc:
    Sand Lake, NY
    Thanks! I guess there's also a chance I'd put a pool table where I'm moving it. :)
  4. Swedishchef
    Swedishchef
    Minister of Fire 2.
    NULL
    Jan 17, 2010
    3,263
    701
    Loc:
    Inuvik, Northwest Territories
    I don't see a problem: just make sure you have the wiring ability at your new location.
    Personally I like having the hwt close to my kitchen. I hate sitting there waiting for hot water when I want to do dishes, wash my hands, etc.
    Good luck!
    Andrew
  5. woodgeek
    woodgeek
    Minister of Fire 2.
    NULL
    Jan 27, 2008
    3,677
    639
    Loc:
    SE PA
    My HPWH is in my garage, about 15' from where my oil boiler used to be. The 'core' plumbing stack in my split level is between the two locations, so no noticeable change in delivery/warmup time.
  6. semipro
    semipro
    Minister of Fire 2.
    NULL
    Jan 12, 2009
    3,119
    490
    Loc:
    SW Virginia
    Floor drain considerations for the over pressure/temp valve?
    We have a GeoSpring and I think a lot about how best to use it to capture waster heat or to provide cool dry air in the summer. I've come to the realization that it would be nice to be able to operate it differently depending upon whether the whole house is in heating versus cooling mode.
    I was thinking in the Summer the GeoSpring air inlet could pull air from the 1st floor and exhaust it to the basement; increasing HP efficiency, cooling the 1st floor, and drying the basement.
    In the winter both intake and exhaust would connect to the basement.
  7. valley ranch
    valley ranch
    Feeling the Heat 2.
    NULL
    Dec 6, 2011
    409
    69
    Loc:
    Ranches in Sierra Nevada mts,Calif & Nevada
    Hi, Tying into the hot water line to move the heater to a place that you like better gets my blessing. Keep in mind the length of run to the 1st use, place of greatest need. I made a correction in the Hot line, slightly longer time for hot water to the dishwasher. If that's no problem or you can tie in at a different location that good too.
    Richard
    velvetfoot likes this.
  8. jebatty
    jebatty
    Minister of Fire 2.
    NULL
    Jan 1, 2008
    5,347
    695
    Loc:
    Northern MN
    Since you are moving an electric hwh, also: 1) raise it off the basement floor and put 4" of foam underneath for insulation, 2) wrap the entire heater in at least 6" of fiberglass or similar insulation, 3) install U-shaped heat traps on both the cold and hot water lines, 4) insulate all hot water pipe that you can get to, and 5) as others said, locate it close to the major hot water use point. These suggestions cut our electric use for hot water by 50%.
  9. velvetfoot
    velvetfoot
    Minister of Fire 2.
    NULL
    Dec 5, 2005
    9,430
    711
    Loc:
    Sand Lake, NY
    All but 5) in the current position. Not looking forward to taking it all apart, if I go that route.
  10. TradEddie
    TradEddie
    Minister of Fire 2.
    NULL
    Jan 24, 2012
    823
    226
    Loc:
    SE PA
    I think you might have some of that wrong. Pulling air from the 1st floor in Summer will increase efficiency, but unless you exhaust back to the first floor, you will not be cooling it, if you cause more outside air to be drawn in, you will be doing the reverse.
    TE
  11. semipro
    semipro
    Minister of Fire 2.
    NULL
    Jan 12, 2009
    3,119
    490
    Loc:
    SW Virginia
    Thanks for the response. I like to get reality checks on things like this.
    The cool air from the basement should rise up the stairway to replace the air pulled to the basement by the HP...at least that's what I'm thinking.
Thread Status:
