I realize the operator is a huge variable here... but all things considered, is one less prone (or maybe worded better... is one more controllable)?
I have to disagree as I got my CDW pretty hot on occasion when starting the stove or reloading and forgetting to close the bypass.. The flames go straight up the chimney when that happens! Maybe the new cat stoves can't do this?Catalytic stoves are more controllable than non-cats. EPA doesn't allow the air to be closed past a certain point on non-cats. This can be remedied by placing aluminum foil, magnets, etc over the air intake, and this seems to be an increasingly popular option with non-cats.
Ray
Wow. I've only had experience with the Fv but I don't see how it could run away unless you left the air at a certain setting early (like '1.25' at least) and then the load got going more later. That said, I've never had a problem; I never leave it open that far. Now, if you're running the stove hotter to heat your space, you are going to be closer to the edge...It is much more comtrollable than the Woodstock Fireview, which itself is very safe and controllable. So, I would say PH has to be high on any list of controllable stoves.
That would have to be considered operator error, though...I have to disagree as I got my CDW pretty hot on occasion when starting the stove or reloading and forgetting to close the bypass.. The flames go straight up the chimney when that happens! Maybe the new cat stoves can't do this?
Ray
Well operator error will give the same result in a non-cat so this really isn't true is my point.. Either stove type will overfire with too much air..Wow. I've only had experience with the Fv but I don't see how it could run away unless you left the air at a certain setting early (like '1.25' at least) and then the load got going more later. That said, I've never had a problem; I never leave it open that far. Now, if you're running the stove hotter to heat your space, you are going to be closer to the edge...
Forgetting to close the bypass is no fault of the stove. I think the question is geared more towards the "I had the air shut down and the stove went nuclear". My Lopi was a non cat and had a bypass no different from my BK, leave either open for too long and you're gonna have trouble.
But if I cut the air on my DW, the fire dies down. When a stove runs away, cutting the air doesn't work.Well operator error will give the same result in a non-cat so this really isn't true is my point.. Either stove type will overfire with too much air..
Ray
I'm not sure a Blaze King would run away with the bypass open, as long as the door is closed. Maybe a load of pallet wood with thermostat wide open. As far as I can tell, and I have been pretty deep into the stove, the only air coming in is thru the thermostat, except for a hole about 3/8-1/2" in diameter that is past the thermostat. There is no secondary air supply that can't be controlled. I can go from raging inferno to lights out in about ten seconds.
Firebox may not get too hot but I know my chimney would be HOT. On a windy day last year I had the bypass open, the stove wasn't even 300* but my double wall stove pipe was 400*+ on the outside with the paint smoking off it. Good thing I had just swept the chimney a day or two before or it could've been ugly.
Can't answer re many stoves, but the Woodstock Progress Hybrid doesn't overfire. Maybe you could if you really tried, loading it full with tiny splits? It is much more comtrollable than the Woodstock Fireview, which itself is very safe and controllable. So, I would say PH has to be high on any list of controllable stoves.
Our stove has never runaway. It's in the exact same location it was 4 seasons ago when I put it in.
You know it has wings it might fly away when your not looking
Pete
Stoves don't overfire. People overfire stoves.
Think of all the wasted rounds !So says the NSA. National Stove Association.
