Is this Okay???
cyclone
161
North East Pennsylvania
Well I didn't get much responses on a post concerning the crock That I needed to replace. So this is what I am doing.
I took out more than half of the old crock. I got Rutlands heat stop and made it nice and neat which I am going to join together with a seven inch crock. So far it looks good and people i spoke to said there will not be a proble.
What do you think????
If you did not read my post this is what it entailed. clay crock was to small fro 6 inch blcak stove pipe. I removed the half of the clay crock and will be joing it together with a neww seven inch crock.
are you talking about the clay thimble where the black pipe enters the chimney?
are you suggesting the removal of the outer most part of the thimble and replacing it with a larger thimble butting to a reduced (original) thimble.
Your plan could work as long as the inner thimble does not reduce the stack flow. Have you tried using a crimper to get the black pipe into existing thimble.
What is the inside dimension (id) of the existing thimble?
murry
a couple other thoughts..
how old is chimney?
is the chimney lined with flue tile?
what is the ID of tiles?
is the chimney inside or outside the house walls?
If no flue then you should consider adding stainless liner!
what is the appliance you're installing?
does the chimney flue have any other appliances installed?
a 6" round pipe is @ 28 cu inches.
a 6" x 6" id flue is 36 cu in.
things to consider....
Okay here are your answers....
Chimney 6 months, newly installed, constructed of masonry cement block
Flu liner 6x6 clays, not round
Chimney located outside
Apppliance wood stove, free standing harman TL 300
No other appliances are hooked up to the chimney
just replace the thimble and be done with it. it's not worth taking the chance of flue gas entering your home.
