    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. rparker Member
    Vermont
    Have an old (1970's?) Jotul 118, green enamel. No issues with heat plates, no cracks. Haven't burned in probably 10 years. Lent it to a family member and when it was returned he had "taken it apart" to make easier to transport. Snapped off a couple of screws inside but unit went back together fine.
    Do these older stoves have any value?
    I could drill, tap and replace the screws, rope gaskets and clean up the stove.
    Can get pics, but it is under a pile-o-stuff in the garage.
    Any opinions, advice?
    #1
    Helpful Sponsor Ads!
  2. webbie Administrator
    Western Mass.
    YES,
    It is worth fixing up. Definitely not scrap.
    This is a classic stove and also works very well. You could say it was the stove that started it all (the modern stove revoluton).
  3. Defiant Minister of Fire
    Old Lyme CT
    Photos:cool:
  4. Ironwood New Member
    Northern OH
    118's are great stoves. We have our 118 in the basement and fire it up when the temps get cold enough. Fix it up to use or sell to someone who can make use of it. Too good of a stove to be in pieces.
  5. begreen Super Moderator
    South Puget Sound, WA
    This is a classic and desirable stove. If the stove is in nice condition, with good burn plates and properly restored with fresh gaskets it could be worth as much as $800 in peak season.
  6. defiant3 Feeling the Heat
    No. NH
    Perhaps, but ALL 118's eventually crack their sides. If you look close to the moose's rear or along side the tree you may see it , but if not then just wait. Not hard to reassemble, and may be worth $800.00 (optimistic perhaps?) but take a look at the Black Bear. Same stove updated, priced pretty well, more features, and likely to provide many good years. The 118 is going to last forever too... if you don't use it much. Just my HO.
  7. begreen Super Moderator
    In my experience the cracks occur when maintenance of the burn plates is poor and the fire has direct contact with the sides. The same goes for the backs of the original 602's which had no factory back burn plate protection. Run properly and well maintained, these stoves last quite well.
  8. rparker Member
    Vermont
    Thanks for the info. I need a small project and I think this will be it. On the inside, should I clean, scrape, etc back to clean metal or should I also paint?
    Will post pics when I get it uncovered.
    Hopefully I can get enough to cover a ton or two of pellets.
  9. begreen Super Moderator
    No need to dress up the interior of the stove. You could wire brush the worst crud off, but no need or gain by taking it down to bare metal and definitely no need to paint. Inspect it carefully for hairline cracks. Reassemble with stove cement in all the seams. If there are broken screws or bolts, no biggie. Drill them out and retap.
