Hello All,
I've been reading this site for about a week now, and must say you're all very helpful and its very informative! So, I just signed up because I have an issue I'm hoping someone can help me with.
I purchased a Jotul C50 Rockland wood burning insert, and I did make sure it fit and everything, except for the lintel part, which I got confused on, and am now stuck. The Rockland's exit pipe comes out the top of the unit. Basically what I need to do is remove the lintel, so I can make room for the chimney liner pipe to attach to the unit.
Here's the thing - I want to remove the lintel - as there are three up there. Two lintels are back to back (angle iron) and are approximately 4" from the exterior face of the fireplace. The 3rd lintel is the one in the way, and its approximately 9" back from the exterior face of the fireplace. I want to cut this lintel out, remove some of the brick above it, and throw the insert in there. What are your thoughts?
I can post pictures as well if needed. Thank you all in advance for your support.
