Jotul efficiency and warranty
jzinckgra Posted By jzinckgra, Jul 16, 2013 at 1:02 PM
Thread Status:
  1. jzinckgra
    jzinckgra
    Feeling the Heat 2.
    NULL
    Jun 12, 2009
    253
    8
    Loc:
    Raymond, Maine
    I scored an excellent craiglist deal on a brand new (still on the crate F55 Carrabasett stove. $1600. In the brochure, it states the overall stove efficiency is 84% while the little notecard inside the stove claims 64%. I assume overall efficiency is different than whatever the other efficiency is reporting or is it a mistake?
    Also, we're having a stove shop install the stove and were told there would be no warranty on the stove since we did not purchase it from them. Can the jotul be registered directly with jotul and still have warranty coverage? Incidentally, I never knew Jotuls were assembled right here in Maine. The factory is only 20 min away from where we live.
  2. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    9,588
    3,990
    Loc:
    Philadelphia
    I suspect the warranty is only to the original purchaser. The term you want to search on is "transferrable". Check both Jotul's warranty statement and local / Maine law for transferrability of warranty.
    There are multiple ways of checking efficiency, and it truly varies with the fuel, air settings, chimney construction, and with what part of the burn cycle you are observing. The 64% number (actually, usually 63%) is assigned by the EPA to all EPA-compliant non-catalytic stoves, as the minimum requirement for a given set of conditions. The 84% number is likely something tested by Jotul, under a specific (but likely different) set of documented conditions.
  3. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,812
    8,589
    Loc:
    South Puget Sound, WA
    That's a great deal. If new and unused, I would think that the stove is warranty qualified, regardless of where it was bought. Was the craigslist sale from a dealer or private purchase?
    Is the stove shop a Jotul dealer? In the least, the installer should warrant his installation. If he doesn't want to send the paperwork to Jotul, then do it yourself. Take pics of the stove still in the crate in case "new" becomes a question.
  4. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    I had a warranty issue after my Jotul dealer went out of business. They didn't want anything to do with it. I finally was able to buy parts through a dealer that used to be a member here.
  5. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    9,588
    3,990
    Loc:
    Philadelphia
  6. joescho
    joescho
    Feeling the Heat 2.
    NULL
    Feb 11, 2009
    362
    59
    Loc:
    Northeastern PA
    That doesn't boost my confidence in them. You actually had to buy the parts instead of a warranty claim? Not good. They should have done something to give you a full service call.
    Makes me re-think mine as well as future purchases.
  7. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
    No different from anybody else. All warranty though the dealer. This dealer had gone belly up.
  8. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Hi jz, the hybrid jotuls (cast over steel shells) are assembled in Maine. Not sure where the castings are actually cast. The efficiency tag inside your stove- 64% was assigned by the EPA I believe, for non-cats and 67% was for catalytics. The mfr normally puts up their lab testings as well. The bottom line- with good dry seasoned wood, all phase II EPA cat and non cat will burn cleanly, more efficiently than their non secondary burning predecessors. As for warranty, much has been said already, I'm not really sure, I do know you got one heck of a good price, congrats. Get that dry wood ready. Good luck.
  9. jzinckgra
    jzinckgra
    Feeling the Heat 2.
    NULL
    Jun 12, 2009
    253
    8
    Loc:
    Raymond, Maine
    This was a private sale from a local guy who says he bought it direct from Jotul. Apparently he "knows" somebody at Jotul that allowed him to buy direct. I will look into the transferability. Yes, the stove installer is a jotul dealer so I will push him on the warranty. thanks.
  10. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,812
    8,589
    Loc:
    If not I wouldn't sweat it. The F55 is a pretty simple stove. Many folks never have a warranty issue.
    webby3650 likes this.
  11. lumbering on
    lumbering on
    Feeling the Heat 2.
    NULL
    Dec 7, 2012
    482
    143
    Loc:
    New York
    In the brochure, Jotul lists the Castine at 84% efficient, but the Oslo at only 75%.
    Is the Oslo really less efficient? Why would that be?
  12. stovelark
    stovelark
    Minister of Fire 2.
    NULL
    Oct 10, 2009
    1,121
    200
    Loc:
    SE CT
    Hi lumbering, don't really think there's noticeable diff in heating efficiencies that we as users would detect. Maybe lab setup and equipment could, but not us. Good dry seasoned wood is the key, always and always.
    webby3650 and Ashful like this.
Thread Status:
