I have searched for other posts regarding this occurence and found that it is quite common on a couple other manufacturer's stoves, but I have not found much regarding Jotul behavior during a high (500-600 degree) cruising temp.
The other night, after knocking the air control down to the <25% setting for the night I flopped down on the floor with the cats (who were playing dead in front of the stove;-) and noticed while the front two secondaries were pushing out the fire from hell, they and the front edge of the baffle plate had a nice orange glow to them. The left side of the deflector above the door also had the beginnings of a very faint glow that subsided as the temp settled in at about 525+/- per the stove top therm. The secondaries continued to glow until a while later when the stoves cruising temp decreased to about 450-475.
My Condar Chimguard STOVE TOP thermometer is in the right rear corner of the top plate (per Jotul manual options) and typically for an overnight burn I will load some hickory, cherry, or sugar in the back with some other junk up front on a nice established bed. After the stove top temp moves past 450 I will turn the air down to 75%, as it reaches 500-550 I will go back to 50%, and in about another ten minutes I will take the air down to the 25% area or just a tad below. The stove settles in at about 525-550 and just cruises beautifully for the night.
I know that the thermometers are not ultra reliable, but the stove seems to be operating ideally with all things considered.
Have other Jotul owners observed the orange glowing secondaries as a fairly regular occurance?
