Yes indeed on the pic's.Took an awful loss but it has to be done. Thanks.
I'm sure you posted about it before,can you say why the rangeley didn't work out for you?
Hello Bub,
If you don't mind tell us a little about your set up. House, square feet, install, many photos, etc. Have wanted a Fireview for quite a while, but thiking of looking at other brands now. They are quite expensive. Then there is that CAT controversy. Can't argue about the Woodstock's customer service though. All here agree it is the best out there.
Tim
Woodstock has a 6 year warranty, replacement free first 3 years then pro rated for 3 more. After the 6th year a new cat will cost you $125.Holy Crap! $100 possibly every 2 years? No way. I was under the impression they were not even making CAT stoves any more.....
Browning BAR,Some like cats, others do not. It's a preference/need. As far as running a cat, it only requires replacing the cat every 2-5 years at about $100 per replacement. If this is too much work/expense for you, then a cat stove is not in your future.
Browning BAR,
The hundred bucks more or less for a replacement CAT has nothing to do with it. If you have been reading the threads since Woodstock went steel you know what I mean. I personally like them. Just think the jury is still out.
Tim
Hello Bub,
Tim
Dennis and others please,Tim. What is the controversy? I don't understand.
Goes back to the thread started by Todd last February (Calling in the warranty ln Woodstock steel CAT"). 281 replies to that thread and several more started since then.
Tim
Tim
Too much heat for his home. I believe he's working with 1100-1300 sq ft and the Jotul was roasting them out. He's going cat so he can run at lower temps.
