Jump starting my pellet stove....Possible causes?
pmf2000
2
Calgary, AB
I have an Enviro EF2. In order to get it working, I have to disconnect the Dial-a-fire (Auger speed control) connection wires from the Auger timer and use a jumper wire between the two pins. After the auger has been going for minute, I then quickly connect the Auger speed control and things seem to work fine (generally).
Any ideas? I have already replaced the Auger timer. I am considering replacing the Dial-a-fire controller but something tells me it could be something else.
That said, if anyone knows where I can get a Dial-a-fire controller at a reasonable price, let me know. It's over a hundred bucks here which seems on the high side.
Thanks!
Tim
Tim,
This is Enviro's link to manuals.
http://www.enviro.com/help/manuals.html
About 1/2 way down page under Pellet Stove are two manuals listed C-10800 Pt 1 and 2.
These should be able to help you identify what is wrong.
Once you figure out what part you need, re-post and someone should be able to help you.
Good Luck,
---Nailer---
