BobUrban said:Rent a dual axle trailer and pullit.
BobUrban said:Do you have a truck? Rent a dual axle trailer and pullit. easier in, easier out and no worry of them fining you for finding a little piece of bark. Just an idea
whatisup02 said:Has anyone ever rented a u-haul to haul a lot of wood at once?
If you have other rental options such as Ryder, you could rent a larger straight truck with 16,000 lb capacity. With an average weight of 5,000 lb for a cord of green wood, that is 3 cord per trip.whatisup02 said:The trucks weight limit won't do what I want it to do.
bluedogz said:whatisup02 said:Has anyone ever rented a u-haul to haul a lot of wood at once?
I'd suggest you equate "a lot of wood" to the truck or trailer's capacity.
1 cord = +/- 2000 lbs.
According to Uhaul.com, their double-axle 6x12 utility trailer has a 2670 lb. capacity with a 4400 GVWR, so anything more than maybe 1.25 cord is over capacity, even if it "fits".
My landscape trailer will hold 2 cord if I stack it right but it's a damn menace to drive it like that.
stee6043 said:Most green hardwoods will weigh a lot more than 2,000lbs per cord. Most likely closer to 4,000 and above.
