Just beginning to research fireplace insert/wood
gebdell
1
Western, MA
Would like to have a fireplace wood insert installed and don't know really what to ask of the dealer/installer. Any basic guidelines for the uninformed? We have a budget of about $2,000.00 for the entire purchase and installation so any suggestions of brand?
gedbel: Welcome to the Forum!! Very slow this time of year. You should know that your thread will get pushed farther down the page unless someone responds or you ask another question...Use the search forum up top to become more familiar with:: Block off plate, ss flex liner, hearth pad, top block off plate. You will have to have an authorized installation for warranties, and possibly insurance coverage,..A dealer will only install it in this manner. You could save money if you can gain the knowledge to do some of the work yourself, but it will have to be certified or pass inspection in the end. Your hearth pad may not extend far enough into the room, however the specs on any given insert will give you the measurement needed(being able to do this yourself could save if needed) Being able to do the liner yourself could help out with your budget. Personally I would want to cut as much cost as possible in order to afford a stove which I would not have to feed every 3 hours. Every one will tell you that wood cut now and split and stacked wont be ready to burn this winter(most woods) Try to find a supplier that has truly seasoned wood (test with moisture meter) Wood supply and learning the stove could take 2 years before you have the best performance from which ever you use. Do some research and repost specific questions as you become familiar with things and your post will stay alive. Hope you have lots of time,,, good Luck!
Take your time with this decision. Depending on the size of the insert, $2k is on the low end of the full install costs. However, with the potential tax-credit, you may be able to stay on-budget when looking at the final total costs. Start with this article to become a more informed buyer: https://www.hearth.com/econtent/index.php/articles/choosing_a_wood_stove.
If you still have questions, no problem. We'll be here to try and help.
Read, google, ask questions. One suggestion is to size the stove to the room or house to be heated....not by the cost. That may sound a little goofy, but a properly sized stove is the BIGGEST decision of the whole system. Buying a $1000 dollar stove that is too big, isn't any better than buying a $2500 stove that is too small.
Room/house layout and size, insulation, windows, chimney/exhaust, etc. must all be factored in to your decision as well. I won't say that it "can't" be done, but 2 grand for a complete, new install is gonna be tough if you outsource your work.
and welcome to the site.
