Most of us read the stovetop temp on the cast near the to flue exit. It seems to be a much better gauge for closing the bypass with the present cooktop.
If your flue temps went down or stayed level and your stovetop temps went up, then, yes, I would say the cat engaged. With the temp climb you note, either the cat engaged or you had really good secondaries, and if you had secondaries you'd know. If the temp stayed up after secondaries slowed down, if secondaries did bring the stove top temp up, then you also can be assured your cat is working. I liked that one could see the cat in the Fireview while h stove was operational. Not so with the PH. But, very soon you'll have a good feel for when the cat engages.
After the stoves had been in operation for a while, it was decided to add a gasket around (over the top and sides of the cat) to prevent air flow around the cat. A rope gasket. If none came with the stove, Woodstock will send you some. Give them a call. I ordered a long length of fairly thick (I think 3/8 inch, but am not sure...they will remember) gasket, because the narrow one they originally sent just disintegrated from the heat of the cat. I had to replace it every time I brushed the cat. The larger gasket I have used all this season and part of last without replacement, and it fits in very snuggly. I keep a thin bladed and handled stainless kitchen knife
(flatware, but cheap) with my stove gear, lay the gasket on top of the cat, and push the gasket in with the knife. When it is new it takes a bit of pushing, but goes in quite easily thereafter.
I agree, the stove does put tremendous heat out the glass. People who have not experienced the stove don't comprehend the amazing heat. This stove is a great and rapid heater. Heats a cold room much more quickly than the Fireview.
Again, enjoy the stove.
