    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. WestVirginian New Member
    Hi everyone--
    This weekend I successfully installed a flexible SS liner in my 25 foot masonry chimney. Yeah! Such a sense of relief. My flue has 2 significant turns in it, so I was nervous, but with three guys it only took about 15 minutes of pushing and pulling (had a rope attached to one end). Hard to believe that 15 minutes saved me $1000 I would have had to pay a chimneysweep (no offense to any chimneysweeps out there ;o) BTW, I ordered the liner from chimneylinerdepot.com, and would highly recommend them. 30 foot liner kit (complete with chimney cap, and "T" at the bottom) was $480 with free shipping. They also do local installations (if you happen to live by them), and they have a lot of knowledgeable chimneysweeps to answer any questions you have.
    Anyway, now I have to connect it to my woodstove (Jotul 500), which I have ordered. The bottom of the flexible liner is a "T", which is about 12 inches from where the back of the stove will be. The guys at chimneylinerdepot said that I could just use a leftover piece of the SS flexible liner to connect the T to the stove. Does this sound right? Any advice, or better ways to do it?
    Thanks for any information. Ian
    #1
    Helpful Sponsor Ads!
  2. Shane Minister of Fire
    Casper Wyoming
    Yeah you could do that or a ridgid piece. Just make sure it rises 1/4" per ft.
  3. Mike Wilson New Member
    Orient Point, NY
    I would use a rigid piece from the stove to your "T" connector. Not too keen on a piece of flex running to a hard "T", then back to flex. Don't know why, just doesn't sit too well with me.
    -- Mike
  4. Shane Minister of Fire
    Casper Wyoming
    Should be fine so long as the liner is supported and the 1/4" rise is maintained without any sagging. The only other advantage to using a piece of ridgid is that to connect the flex you'll probably need two more adapters.
Thread Status:
