kick back
bjkjoseph Posted By bjkjoseph, Mar 31, 2008 at 8:07 PM
Thread Status:
  1. bjkjoseph
    bjkjoseph
    Member 2.
    NULL
    Mar 31, 2008
    239
    8
    Loc:
    long island
  2. Henz
    Henz
    New Member 2.
    NULL
    Mar 23, 2006
    1,735
    4
    Loc:
    Northville, NY
    no, I would say worse, it has longer reach to hit you with!
  3. Corie
    Corie
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    2,430
    1
    Loc:
    Halifax, VA
    Think about what kick-back actually is. It's an unplanned "moment" (rotational movement). Since torque is always a function of force and distance, the further away the force is applied for you, the more rotational strength the moment has at the center of rotation.
  4. Jags
    Jags
    Moderate Moderator 2.
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    Listen to all that engineer type stuff. %-P
    Nothing to add - Corie nailed it.
  5. Henz
    Henz
    New Member 2.
    NULL
    Mar 23, 2006
    1,735
    4
    Loc:
    Northville, NY
    I seriously would stay with a maximum of a 20" bar for bucking firewood.
  6. Eric Johnson
    Eric Johnson
    Mod Emeritus 2.
    NULL
    Nov 18, 2005
    5,875
    147
    Loc:
    Central NYS
    A longer bar is actually more likely to kick back in part because you don't have as much control over the force exerted during a kickback, and you're much more likely to stick the tip (which is where kickback originates) into a kickback situation, since you're farther away from it and, again, have less control over where it goes.
  7. Henz
    Henz
    New Member 2.
    NULL
    Mar 23, 2006
    1,735
    4
    Loc:
    Northville, NY
    Here is a question that I have. How is it that when you are doing a bore cut, you do not experience kick back. I mean, your sticking the end of the saw into the tree. I know that you use the bottom part of the tip to start but then you are litterally pushing it straight into the tree..Comments???
  8. Eric Johnson
    Eric Johnson
    Mod Emeritus 2.
    NULL
    Nov 18, 2005
    5,875
    147
    Loc:
    Central NYS
    As I understand it, in a bore cut the tip has no option but to cut wood. Since it's in a confined groove, what would be kickback force if it was in the open would result in either the saw stalling or wood being cut. In other words, the saw tip can't kick back out of the bored area.
  9. Henz
    Henz
    New Member 2.
    NULL
    Mar 23, 2006
    1,735
    4
    Loc:
    Northville, NY
    yeah thats basically the wya I see it too
  10. WarmGuy
    WarmGuy
    Minister of Fire 2.
    NULL
    Jan 30, 2006
    518
    42
    Loc:
    Far Northern Calif. Coast
    But I'm guessing that with a shorter bar, the chainsaw is going to rotate faster when it kicks back. The force is applied closer to the center of the rotation.
  11. Jags
    Jags
    NULL
    Staff Member
    Aug 2, 2006
    17,499
    6,074
    Loc:
    Northern IL
    I "think" the answer to this is: you are dealing with the same "speed" of chain being applied to less leverage (shorter bar) and therefore the reaction should actually be slower.
Thread Status:
