I have a Englander PAH and want to perform leaf blower trick this weekend (after it finally warms up). My question is do I have to disconnect anything within this stove so I don't damage internals? Or just hook up & let it fly?
I have a question about the leaf blower trick.I have my exhuast pipe going thru tje side wall into a clean out tee. That is placed at a slight angle. My leaf blower is a large gas engine one that has a back pack attached to it. The snorkel on the leaf blower comes apart in 3 different peices. The largest peice is about 3 1/2 inches dia. Is it possiable that I can take the clean out cap off and blow up thru the 3 inches chimney. Creating a venturi effect on the stove ?
Man, to me it doesn't seem like that would work to well but I guess you could give it a try.......I don't think you would get enough vacuum effect out of that but what do I know...lol
I must apologize, for my previous comments - somehow, while searching for your previous posts - a different member (who DID have problems with his stove), came up, and I mistakenly , assumed, it was you. Sorry for throwing a monkey wrench, into your thread.
No biggie, thought I missed something earlier...lol
I wouldn't use your expensive backpack leaf blower on the leaf blower trick. Just get a $40 electric leaf blower.I have a question about the leaf blower trick.I have my exhuast pipe going thru tje side wall into a clean out tee. That is placed at a slight angle. My leaf blower is a large gas engine one that has a back pack attached to it. The snorkel on the leaf blower comes apart in 3 different peices. The largest peice is about 3 1/2 inches dia. Is it possiable that I can take the clean out cap off and blow up thru the 3 inches chimney. Creating a venturi effect on the stove ?
[quote I wouldn't use your expensive backpack leaf blower on the leaf blower trick. Just get a $40 electric leaf blower.
My plan is to just take the end cap off the clean out tee and blow up through the tee and through the 3 inch chimney. Createing a venturi. Very simular to how clam boats dredge the bottom. My blower will only blow air and no way to convert it to suck out.My chimney cap is about 8 feet above me.
I understand now. However, you won't get as much sucking power that way, and you will likely get a cloud of ash right at your stove pipe exit! Using the cheap leaf blower trick, you can aim the ash cloud, and shoot it away from the house. Did I mention it's cheap? $39. Some have gotten them for less.My plan is to just take the end cap off the clean out tee and blow up through the tee and through the 3 inch chimney. Createing a venturi. Very simular to how clam boats dredge the bottom. My blower will only blow air and no way to convert it to suck out.My chimney cap is about 8 feet above me.
