    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Shane Minister of Fire
    Casper Wyoming
    Hauling pellets is tough on my suspension (1995 Dodge Ram 1500 4x4 w/ 360) I was wondering if anyone has experience with the leaf spring levaling kits. Do they work well/worth the money?
    http://www.4wheelparts.com/PLT4109T8T2.aspx
    I'd be considering the super duty rear ones listed at the bottom of the page.
    #1
    Helpful Sponsor Ads!
  2. Firewoodguy.com New Member
    Londonderry, NH
    I have used them before and works fine, though installation takes some time. Just a suggestion to save you money and time, ever think of hauling fewer bags of pellets for safety reasons ?? ??
  3. Shane Minister of Fire
    Casper Wyoming
    Buy them by the Pallet which is 60 bags wrapped nicely weatherproof etc. Breaking them down ads exponentially to my fuel and time usage to haul my pellets. Plus I always like fixing up my truck :)
  4. keyman512us Member
    North Worc. CTY MA
    Shane...
    ...Having said the above "fixin my truck"...you just might be "gittin' what you wished for" if you aren't carefull. lol :)
    Leveling the springs might be "a double edged sword". IMHO spring levelers' and all the other gizzmo's should be considered to "increase" handling vs. loading on more weight. Again...a double edged sword. You can "beef up" the springs all you want...you are still riding on the same wheel bearings, seals, brake components and numerous other parts. Generally people learn a valuable (and costly) lesson this way...stiffening the springs usually just transmits more "abuse" to more vulnerable parts when carrying heavy loads.
    Honestly...my advice to you...consider (seriously)hauling with a trailer, your truck will "thank you" for it. :)
  5. elkimmeg Banned
    Also the tire load rating You stiffin up that spring you may loose traction in wet conditions. the truck may not handle quite the same without it being loaded you rear end can kick out then you need to change shocks as well I like Keymans idea of getting a trailer
  6. Shane Minister of Fire
    Casper Wyoming
    Maybe I will look at a trailer instead. It's just a matter of 1k vs. 350 bucks. As for the handling empty I think it would be ok since these are airbags and can be deflated when not being used.
Thread Status:
