lighting a coal stove
rowefam Posted By rowefam, Dec 12, 2005 at 12:36 AM
Thread Status:
  1. rowefam
    rowefam
    New Member 2.
    NULL
    Dec 12, 2005
    2
    0
    We just bought a home with a Warm Morning Coal stove and cannot seem to get it lit. We have never used a coal stove before and are really at a loss. Any help out there?
  2. lime4x4
    lime4x4
    Member 2.
    NULL
    Nov 18, 2005
    134
    0
    Loc:
    Northeast Pa
    you could either use kindling or most stove shops have this little boxes for starting coal called mice i beleive.There a little white box with a fuse on it.Set the box in the fire box pack a little coal around it and light the fuse.And make sure u close the door real fast cause they really smoke.
  3. rowefam
    rowefam
    New Member 2.
    NULL
    Dec 12, 2005
    2
    0
    Being that we are truly ignorant, does the coal burn in the pan in the bottom of the stove or in the part of the stove where you dump the coal into?
  4. BrotherBart
    BrotherBart
    NULL
    Staff Member
    Nov 18, 2005
    32,824
    9,888
    Loc:
    Northern Virginia
  5. Corie
    Corie
    Minister of Fire 2.
    NULL
    Nov 18, 2005
    2,430
    1
    Loc:
    Halifax, VA
    coal burns on the grates, the pan in the bottom catches the ashes.
    I highly recommend reading craig's primer on burning coal. It will be a big help in getting you started.
    Secondly, the easiest way to light a coal fire is charcoal. NOT matchlight and NO LIGHTER FLUID.
    Build a small wood fire with light kindling, then proceed to add charcoal (briquettes or lump, doesn't matter). As the charcoal starts burning intensly, you may SLOWLY begin adding coal. While you're doing all of this, make sure the underfire draft control is fully open, as it takes a lot of draft to get coal to light. As the coal you're adding catches (yellow flames, crackling, the actual coal glowing red) begin adding more and more.
    After you have a good amount of coal burning hot, fill the stove to capacity. That part is important. Then, after all the coal in the stove is burning, set the air control at a reasonable level and enjoy.
    At least twice a day, you'll have to shake the ashes off the coal and add fresh coal. The procedures are well described in Craig's write up.
Thread Status:
