dmbehm said:
I had an energy audit done and was told that the fp blower i was using would be better replaced with an insert.
I am very new here and me looking at this lopi in a day or so SN# is 20686
http://denver.craigslist.org/hsh/2199494347.html
Looks good from the pics.
Being new here do I have to install with a chimney liner? I just had my fireplace cleaned about 1.5 years ago and had several cracked tiles replaced.
I like to use the fp to heat the 2100sq ft house vs paying the high heating bills.
Thanks for all the help and answers
dmbehm:
You can't go wrong installing a new insulated chimney liner. Here's why:
There are several conditions where “the (existing) chimney or flue may not be acceptable for a woodstove, hearthstove, or a fireplace insert including:
1. absence of flue liner
2. condition of liner (cracked, broken)
3. size of flue liner (more than the maximum cross-sectional area in relation to the appliance collar size)
4. failure of chimney to meet clearances
Performance and safety can be improved with a stainless steel or poured liner system by:
1. proper sizing
2. insulation that keeps the flue gases warmer (reduced creosote and maintenance)
3. easier maintenance
4. tested temperature limits.â€
All of the above is quoted directly from Heart Handbook for Building Officials - Solid Fuel Hearth Systems.
To make a long story short, in my case I had to go from a 13 inch X 13 inch terracotta interior (inside the house - not external) flue liner to a 6 inch diameter appliance flue collar. The 13 X 13 inch is a cross sectional area of 127 square inches. This was more than the maximum allowed 84 square inches (6 inches = 28 square inches cross section area X 3 (allowed) = 84 inches squared. So I relined with an insulated 6 inch SS Flex King Pro liner.
The NFPA and IRC states that “the cross-sectional area of the flue of a chimney with no walls exposed to the outside below the roofline shall not be more than 3 times the cross-sectional area of the appliance flue collar.â€
So if your building jurisdiction uses the IRC (at least the 2000 edition of the IRC), then a smaller liner may be required.
Any number of inserts are capable of heating a 2,000 sf house. That said, I would choose the largest one that will fit your existing fireplace. BTY, you might be able to install a hearth stove if you don't mind taking up additional space on the hearth - and perhaps making the hearth larger.
Good luck with your install.
