Locking file handle
oilstinks
585
western NC
A buddy of mine showed me a file handle that locks in the file with a twist of the handle. It is orange and shows angles on the end. Anyone know where I can get some of these or who they are made by
should find them at any stihl dealer
Never seen them at any store around here. The only sthil dealers around here are hardware stores ACE in particular. Anyone wanna send me 2 or 3?
yea i will send you a couple pm your address!
I haven't seen one that locks by screwing the file into it, but I've got a couple that are made by Husky, which I got at the local True Value dealer in his saw department (which includes Husky's and Stihls, among others) They are made from some sort of poly-plastic, and have an outer skeleton section and an inner section that is attached at the end opposite the file - you have to flex the two sections (takes a bit of effort) to line up the holes in the two sections that you stick the file into, then the tension holds it in place - The sides next to the file are beveled, 25* on one side, 30* on the other. If the handle hits flat on the bevel when you run the handle into the bar you are holding the file right.
I think they were about $3 or $4 each, and work really well
Gooserider
