I'm looking at buying a high efficiant wood boiler and have been sent information about Portage & Main stoves and the Ultimizer series. Is there anyone that can give me any advice about this type of stove?
I would rather have an outdoor boiler. I have a central boiler at the present time and just looking to update it to a higher efficiency boiler. I have some greenhouses I heat in the spring and would like to have a boiler that burns the fuel to ash instead of charcoal.Hi Rockcrusher.
If you tell us a little more about your situation, what you are trying to heat, if you are looking for indoor or outdoor boilers, etc., everyone here can provide more helpful information.
I have a CL17, 170 gallon CB stove. When I start using heat in my greenhouses I burn about 1/2 cord a week. I fill it at 10pm, 2am and then 6am, it just doesn't have time to burn all the wood into ash before I need to put wood in again. So I thought a boiler that was higher effeniency wood burn better, plus I added a 1200 gal storage tank into the system.what model CB are you currently running?
how much wood are you burning for your current setup?
I also heat my shop with it and through the winter I will use 1/2 cord a month heating that. Then when I start the greenhouses it goes up to 1/2 cord a week. My wood isn't all that dry, that is why I haven't thought about using a gasification system. Then I talked to a salesman about the Portage & Main stoves where he said it is just about as good as a gasifier boiler and yes I know I will have to use dryer wood. I more or less would like to know if you have heard anything about these stoves or prefer a different make?assuming your tank is insulated and in the greenhouse?
and you are using an air handler to push FHA into green house?
and your cordwood is dry?
Look up KarlK he is my brother and has one .He likes it a lotI also heat my shop with it and through the winter I will use 1/2 cord a month heating that. Then when I start the greenhouses it goes up to 1/2 cord a week. My wood isn't all that dry, that is why I haven't thought about using a gasification system. Then I talked to a salesman about the Portage & Main stoves where he said it is just about as good as a gasifier boiler and yes I know I will have to use dryer wood. I more or less would like to know if you have heard anything about these stoves or prefer a different make?
thank you for the word on PnM boilers. I burn 1/2 cord a week for anywhere between 8 to 12 weeks depending on the weather.just curious, aprx how many weeks where you burn 1/2 a week?
BTW, on this board i don't think I've heard bad thing about PnM. Looks like a good unit.
