I have a Lopi Declaration for about 3 months now.
Last weekend I used foil tape to seal between the firebox opening and in the insert (behind the trim panels), all the way around. I did this just to eliminate any cold draft coming in the house from around the firebox when not in use.
After that I started a fire, and to my surprise it didn't draft properly. It's never had a problem drafting in the past at all. This didn't really make sense to me, so I quickly pulled the little strip of tape I had put on the bottom before too much smoke came in the house, and it started drafting properly right away. I can't really explain this, but it got me thinking, where is the air intake located on the Declaration ?? The way it acted makes me think that it is drawing air from the sides/bottom/back (ie anything other than the front). Is this true ?
If so that means I could in effect setup a cold air intake by providing an air path to the fireplace cavity (via hole through chimney, ash dump etc..) , while sealing the opening as I had done.
I'd really be interested in doing this, as I don't like the idea of the fire pulling heating air from the house for combustion.
So does anyone know where on the declaration exterior the combustion air actually enters ?
Thanks
Thanks
