I hear in many comments on this forum about it not being good running a stove with air control wide open because you lose a lot of heat up the flue.
I've been trying to understand this in relation to my Lopi stove, and I don't think it applies.
The Lopi has a by-pass at the top of the stove which you use when you open the door. The by-pass opens a slot at the top of the firebox which lets all the smoke and gases directly up into the flue. But, this by-pass has nothing to do with air control.
The air control knob is at the bottom of the stove.
So, my question is this: If I run with the by-pass closed and the air fully open, I am not losing tons of heat up the flue, right? The fire is still being forced to run through the firebox, down the airwash, etc. I may be burning up my wood faster, but I'm not losing heat.
If I am wrong about this would someone please explain it.
Do other stoves not have this by-pass feature?
