SmokeyTheBear
Pat10 said:most pellet stoves 35-1 ratio" is vague. i like your disclosures & wish other stoves would also.Franks said:BDPVT How does the fact that most pellet stoves use a 35-1 fuel to air ratio as opposed to the 10-1 fuel to air ratio on the Europa factor into the equation? I had Claude explain it to me (part of which was patented info he asked me not to share) I wanted your thoughts. Also, he said I could pass on your response to him and if you were close to one of his trade secrets, he may just email you directly and discuss it further.
ask franks what happens if i simply put a light dimmer on my exhaust blower to cut down the 35-1 ratio?
I can even answer that one, however the reason that the 10 to 1 air works for the Europa and results in a clean burn is the key and if you go digging you might discover how that comes about.
You do that with your stove and the pellets will pile up and end up in the ash pan.
