Highbeam said:If you go the antiseize route don't be put off by the small size of the antiseize container. A little goes a long long ways. I am still using the same tube after about a decade of use on spark plugs, and bolts. It seems to have a metal content which might make me a little nervous about using it on battery terminals. For that there is another fine product, dielectric grease which is non-conductive. I use that stuff for all of my non soldered connections and plugs.
If the latch makes a scritch feel as you work it then you need to lube the coil spring/washer interface. If it makes a low tone rumble as you latch the door closed then you need to lube the door latch interface with the stove. I would lube both but the spring washer interface needs to be done with either a liquid or with some sort of disassembly.
