    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Cleetussnow New Member
    Westchester, ny
    Hi all
    I wonder if all other m55 owners experience periodic high pitch fan whine, especially whe the stove is on a cooling cycle. Mine does it on auto off on, not high low Mode.
    Anything to sweat?
    #1
    Helpful Sponsor Ads!
  2. flynfrfun Minister of Fire
    Bonney Lake, WA
    Depends on whether or not you have the new convection blower. The old blower is supported on one end with a bushing which will eventually squeal. The new blower is supported on both ends by ball bearings and shouldn't make any abnormal noise.
  3. nailed_nailer Minister of Fire
    Cape Cod, Ma
    Mine is quiet, but I only run in Hi/Low
    ---Nailer---
  4. Don2222 Minister of Fire
    Salem NH
    Hello
    I had an Enviro EF-2i that had a wicked high pitch wine all the time. Finally replaced with a generic A082 Fasco Blower and now it is wisper quiet!
  5. stovelark Member
    SE CT
    Hi clee, in cooling down mode, the convection blower shifts to high speed to dissipate heat quick and shut off everything. Could that be the issue even these super quiet units Enviro makes (Sherwood makes your stove for Regency too) can be a little noisier on high speed (5).
    Stovelark
    Enviro EF3 pellet FS
    Enviro Empress FPI AC
    Enviro Kodiak 1700 FS wood
  6. flynfrfun Minister of Fire
    Bonney Lake, WA
    Actually, it depends on which version motherboard you have. My convection blower stays at the same fan setting during shut down. So, if it was running on heat level 1, the blower stays at heat level 1 speed during shut down.
  7. stovelark Member
    SE CT
    Thanks for that info fly, hadn't heard of that.
    Stovelark
