Hey guys, thanks for the direction on the dwyer markII. A few questions...
I installed it and made my own probe out of a piece of brake line to slip inside the flue thermometer collar.
I measured it off the high side of the meter because you have a bigger range. Are you guys using both lines or just one.
At cold flue temps with no fire and outside air temp of 45 degrees I am seeing .01, left the stove door open and shut it again after it had some warm air up it, it went to .02.
After starting a top down fire it went right away to .05 and then fifteen minutes with a wide open fire it was up to .09
Will post more with secondary combusting and some pics.
Is this a normal reading. 16 feet of 6" stainless liner in a center brick chimney and no insulation, flue cap and all.
Thanks guys!
Thanks guys!
