moisture meter
wingsfan
371
Jackson,Mi.
I bought one several months ago and have had no problems with it. The ideal moisture content of seasoned firewood is less than 20%. I use my meter with wood in my kiln and when the ends read 0 the inside of the wood is usually less than 20 as I have split many pieces and tested them.
I have the one on eBay but it is the 4 pin meter. It does seem to work but wonder what reading on the end means the wood is really dry. If the end reads 17%, is the wood still too wet to burn? The maple I cut last spring is reading around 17%, some elm that had been dead for many years reads around 6%.
I have the harbor freight one as well and it seems to read correctly as to what my wood is. In other words my three plus year old wood shows 6% and ash that I cut and split mid summer stacked in my yard uncovered tested yesterday at 20%.
The harbor freight one is kind of cheap looking but seems to work well so far. A quality unit will cost around $100. I figured the harbor freight one was worth a try and I have been happy so far.
I have the cheaper Harbor Freight one- with two pins, non- digital readout. I like it. I suspect it is fairly accurate. I got mine for just under 10 dollars by receiving the mailer and using a 15 percent off coupon, plus catching a sale. That model can be had for 15 dollars any time.
