    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Val New Member
    Hello, can you help me find a brand of monoxide detector that doesn't shut down in 7 years? I'd like a plug in one. They cost 30-50 dollars and then before you know it the things not good anymore. I had 2 battery ones, now the last one is chirping its replacement signal. I am not trying to be cheap with safety...I just think its another gimmick to get consumers to spend. Thank you.
    #1
    Helpful Sponsor Ads!
  2. Frozen Canuck Minister of Fire
    Generally speaking most brands have detector failure within 5 - 8 years or so. They just get all gummed up with what's in the air in our homes. If you smoke in the house or have pets or a poorly maintained forced air system, failure can occur sooner. Good practice & required by some insurance companies is replacement within that 5 - 8 year period. Sorry to burst your bubble on something that last's forever as no one has invented a self cleaning detector yet.
  3. TradEddie Feeling the Heat
    SE PA
    It's not dust or dirt, the chemical sensor in the CO detector wears out. This is not like a smoke detector which can be vacuumed. This is one reason I use separate smoke and CO detectors.
    TE
  4. ccrider New Member
    Kidde has just released a 10 year co detector. This is an industry first. Ul requires that your co alarms at the end of life which had been 7 years and now will be ten years.
    Btw, it is a good idea to vacuum your smokes but regardless nfpa recommends your replace them after 10 years regardless.
    firebroad likes this.
  5. EatenByLimestone Minister of Fire
    I just had to replace one that failed after 3 years.
    It was a Kiddee plug in model.
    Matt
  6. ccrider New Member
    Should return it under warranty. The date code is on the unit
  7. EatenByLimestone Minister of Fire
    I have it sitting on a shelf and am waiting to do it.
    Time is the limiting factor on most things I do.
    Matt
