Seems like people talk about big heavy stoves as being the most efficient. I guess this is motivated by the retained heat that allows longer refueling cycles.
I recently installed a BIS Nova fireplace, which as the name implies, is really a Built In Stove. Airtight firebox, adjustable inlet air, secondary burn. This unit is on the other end of the scale...its mostly made of lighter sheetmetal. The whole unit weighs about 225 pounds.
I'm wondering which is really more efficient. In my mind, stove efficiency is the amount of the BTU's that make it from the wood into the house. In an airtight stove, that seems to me to be every BTU that doesn't go up the chimney, either as unburned wood, or as heat lost through convection.
Doesn't all that retained heat in a heavy, high-thermal-mass stove really encourage more heat to be lost up the chimney? Seems to me the longer the firebox stays at an elevated temperature, the more time for heat to be lost to convection up the stack.
On the other hand, my BIS Nova doesn't have all that mass, and it seems the heat is more likely to travel out of the stove and into the room. It doesn't have all the retained heat of a big cast iron or soapstove stove, requiring more frequent refueling. But it appears that in terms on BTU's delivered to the living space, it might be more efficient overall. And the firebox seems like maybe it gets hotter faster so the secondary burn is more effective, helping combust unburned fuel (very little smoke).
Interested in your thoughts...
bottom line is all units are going to put out heat, we just have to figure out the best way to transfer it into the home.
