I know my old wood furnace is not like your EPA stoves, but you guys should have some idea as to what is going on here. First, a little about the install. I have a Daka add on-furnace that is hooked up to my central heat ducts. I have 1000-cfm worth of fans on the Daka. The combustion air is controlled by a door that is raised and lowered by a bi-metal coil t-stat. The theory is, you set the dial to a spot between Off and High. As the furnace heats up, the door is lowered and limits the air to the fire. The blowers kick on via a snap disc t-stat on the air jacket. Just as a note, the fans do not turn off until the fire is complete out and most of the coals are out too.
The furnace room is boxed in and there is probably not a lot of air movement in there. It does get plenty hot because of the radiant heat coming off the furnace and the stove pipe.
I'm burning hardwood that has been cut/split/stacked in the sun and wind for two summers now. Most pieces do not even have bark. When put on a bed of coals, it lights right away, and my magnetic thermometer on the stove pipe gets to 600° quicker than I've ever seen before.
Typically, I will load wood into the furnace, let it burn nice and hot (500°-600°) for a few minutes and then back the air down in stages. At the final stage, the door will typically be fully closed, but it does have two holes in it that are about 3/8" in diameter so it is not air tight. The last few nights, I've gone outside after my kindling fire and see very little smoke. However, once I load the furnace, I'm getting a fair amount of white smoke coming out of the chimney. There is no black or blue smoke and the chimney cap is remaining fairly clean.
What would you guys say is going on here? I'm keeping the air open too long and getting the furnace too hot so it shuts the air down too much? Not enough air movement in the furnace room for the intake air? Too much static pressure from the large fans and small 8" ducts off the top of the furnace keep the fire jacket too hot too long?
