Motor stuck in auger, Magnum Baby
GMadd
114
Highland, NY
I'm replacing my Delron auger bushing on my Magnum Baby and things seem to be going well.....but. After loosening the screw I had a heck of a time separating the motor and the auger. They seemed to be frozen together. What can I lube this with to prevent it from freezing in the future?
Smear a little high temp never seize on the shaft. It's available at most hardware or automotive stores. I also use it for any screws that I remove that are in high heat areas. Makes
It much easier to take things apart later and prevents stripping screws.
Reactions: GMadd and Bioburner
Part of the problem may be that the shaft mushrooms a bit when you tighten the screw very tight. Mine didn't want to go back together again until I did a little filing on the shaft. I didn't overtighten the set screw when I reassembled. I'd rather have it come loose than have to fight the auger/motor again. I had to use a 3' pry bar to get them apart. No rust involved, just the mushrooming of the shaft. Using two set screws, one on top of the other, may help.
Reactions: GMadd
A little sand paper did the trick. I believe it was previously over tightened. I also added never seize for some insurance. Thanks guys! It's working great now!
