    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. davedmaine Member
    Maine
    Hi. I recently switched from a softwood to hardwood pellet. The first bag burned fine. But now, I keep getting 'minimum firepot temperature' messages (the hopper is full).. I restart it, it burns fine for a while, and then I get that message again and it shuts down. Seems strange that it would be happening the same time I changed pellets. Any ideas? Thanks,
    Dave
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    Did you change the fuel selection on the wall thermostat to hardwood?
    "Pellets made from hardwoods (i.e. oak) have a higher ash content
    than pellets made from softwoods (i.e. pine). The hardwood
    pellets may require more air to burn properly so make sure you
    have the wall control on the correct setting."
  3. davedmaine Member
    Maine
    Hi. Yes, I changed the setting to hardwood..
  4. kinsmanstoves Minister of Fire
    Set it back to hardwood and see what happens.
    Eric
  5. smoke show Minister of Fire
    Pittsfield, Wi
    try utility setting. when was the last time you cleaned the stove and venting?
  6. LMPS Feeling the Heat
    Coastal, Maine
    Sounds like it might be a thermocouple issue. Try taking the TC cover off and cleaning under it adjust the TC if needed so its over the firepot. Thinking it might just be a case of 1+1=3. Also, what is your flame height adjustment at? Might try adjusting it up so it feeds more pellets.
  7. begreen Super Moderator
    That was my thought. If it's not working well on the hardwood setting, give the flame height a little boost. Also, make sure the burnpot is clean.
  8. davedmaine Member
    Maine
    I've tried all the suggestions aboe and I'm still having the same problem: It will burn for a while and then the 'minimum firepot temperatue" message pops up (the stove is full of pellets). Also, it's taking it a very long time for it to start up..
  9. joescho Member
    Northeastern PA
    Then either you don't have enough air to keep the fire going, or your stove is not supplying enough pellets to keep the fire going. Either way, clean your stove. In addition I would also empty the hopper out as best you can and clean out both the pellet chute from both inside the stove and stick a vaccum down the hopper. I had a similar problem once and it turned out a jammed auger. Once I cleared the jam it was like I won the jackpot on a slot machine and a whole pile of pellets came out the chute. If its air supply problem then cleaning the stove will help. It certainly won't hurt. Get your manual out and clean all of the areas it talks about in the manual even if you think they won't be dirty.
    kinsmanstoves likes this.
  10. kinsmanstoves Minister of Fire
    venting might be clogged and not be allowing air to flow.
  11. LMPS Feeling the Heat
    Coastal, Maine
    Did you resolve this issue? What was the problem?
    smoke show likes this.
