    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. jmlarson New Member
    Central, PA
    Installed my Mt Vernon AE this past weekend. Anyone tell me why the flame height is strong some times then it barely leaves the burn pot at other times. Burning Premium Hardwood Pellets on hardwood pellet setting. Temp set at 68 deg. any help is apperciated.
    #1
    Helpful Sponsor Ads!
  2. Philip New Member
    Huntsville, AL
    I'm new to pellet stoves, too, having just installed mine last Friday. On level 1 and 2 my stove seems to flare up and then die almost out, also, but it seems to have a more consistant flame on levels 3, 4 and 5. I think it is tied to the pellet supply in the burn pot. When I have it set on level one - the lowest - the auger doesn't feed the pellets very fast and since the pellets range from 1/4" long to 1" long, if the auger drops a 1" long pellet into the burn pot, the flame builds up more than if the pellet is only 1/4" long. My manual says I may not be able to leave the stove on level one because it may go out. It also says the size of the pellets will change the volume of fuel being fed. I moved it to level 2 last night to be sure it didn't go out during the night.
  3. Deed Member
    Central Me
    It all has to do with the amount of fuel in the burn plate. The more fuel the more flame.
  4. jmlarson New Member
    Central, PA
    I have my flame height setting on +4 right now and it actually looks like a good flame. seems like a high feed rate though. I figured out that i do burn less pellets on Utility setting rather than Hard Wood setting.
  5. Jabberwocky New Member
    Central Massachusetts
    My flame height does not stay the same. I run mine on auto all the time and my flame height adjuster is set at 0. I think the way I set up mine, the circuit board is doing all the work and so it drops various amounts of fuel to render consistent heat flow .. then when it gets close to the desired temp the stove kicks into low so as to not have to restart 15 minutes later.
  6. bdcbean New Member
    New Zealand
    edit:
    Old thread. sorry posted by mistake..
Thread Status:
